跳转到主内容
ATT CL4940 Internal Speaker Replacement
你所需要的
  1. ATT CL4940 Internal Speaker Replacement, Internal Speaker: 步骤 1 中的图像 1,2 ATT CL4940 Internal Speaker Replacement, Internal Speaker: 步骤 1 中的图像 2,2
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Speaker Replacement: 步骤 3 中的图像 1,3 ATT CL4940 Internal Speaker Replacement: 步骤 3 中的图像 2,3 ATT CL4940 Internal Speaker Replacement: 步骤 3 中的图像 3,3
    • Starting from the bottom of the device, use a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Speaker Replacement: 步骤 4 中的图像 1,1
    • Using wire cutters, sever both the red and black wires connected to the speaker.
    • Carefully remove the speaker from the assembly.
    • Be sure to remove the rubber gasket from the broken speaker. You will need this for reassembly.
结论
Charles Moore
于02/16/16注册
201 声望
创作了2篇指南
团队
IUPUI, Team 2-2, Harley Spring 2016 IUPUI, Team 2-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S2G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 11
总计 400
