跳转到主内容
ATT CL4940 Internal Microphone Replacement
你所需要的
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: 步骤 1 中的图像 1,2 ATT CL4940 Internal Microphone Replacement, Internal Microphone: 步骤 1 中的图像 2,2
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: 步骤 3 中的图像 1,3 ATT CL4940 Internal Microphone Replacement: 步骤 3 中的图像 2,3 ATT CL4940 Internal Microphone Replacement: 步骤 3 中的图像 3,3
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: 步骤 4 中的图像 1,1
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
结论
Charles Moore
于02/16/16注册
201 声望
创作了2篇指南
团队
IUPUI, Team 2-2, Harley Spring 2016 IUPUI, Team 2-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S2G2
4 名成员
创作了8篇指南
一条评论
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 19
总计 647
