简介
This guide is used to provide step-by-step instructions for performing the replacement of the Start/Stop Button on the AT-LP120-USB. This procedure is used to resolve inconsistent or no functionality of the motor when the Start/Stop button is pressed.
No soldering is required to perform this repair.
你所需要的
Disconnect your turntable from power and audio.
Move the turntable to a clear flat surface.
In this step, we are removing the necessary accessories to mitigate the possibility of damage in the upcoming steps.
Engage the tone arm clamp
Remove 45 adaptor.
Remove slipmat.
Remove platter by using the two circular holes and pulling vertically from the top of the turntable.
Remove the counterweight by unscrewing the rear clockwise.
Carefully flip the turntable onto the dust cover.
Remove 8 screws.
Spin the turntable so that the rear is facing you.
Lift off the bottom cover.
As you pull the bottom cover off, the RCA cables will be removed through this hole.
Spin the turntable back around such that the front is closest to you.
Locate and collect the 8 brass bushings if they did not come out with the screws.
Slide the bushings to the head of each screw and set aside for later.
The button that is being removed can be located here.
在这个步骤中使用的工具:Tweezers$4.99
Adjust the turntable on top of the dust cover such that the button is protruding from the PCB.
Use a pair of tweezers or needle-nose pliers to remove the silver clamp.
Remove the black felt washer from the post.
The button is now loose and is able to be removed.
Adjust the turntable so the dust cover is no longer holding the button up.
Remove the button and spring if it did not fall from adjusting the turntable.
Remove the spring and black felt washer from the button shaft.
Locate your replacement button and place it such that the black plastic post is closest to you.
Slide the black felt washer down to the base of the shaft.
Position the spring around the shaft in-between the small plastic posts.
Insert the button back into the base of the turntable with the small highlighted post from Step 9 closest to you.
Slide the black felt washer onto the shaft of the new button.
Press the clamp back into the grooved portion of the shaft.
Spin the turntable back around such that the rear is facing you.
Place the hinges back into the dust cover.
Press this part of the hinge so the hinge is in a vertical position.
Locate the bottom cover, and route the RCA cables com from the turntable through this hole.
Place the bottom cover onto the turntable such that the dust cover hinges are inserted into their respective brackets, and all ports are visible.
Insert the 8 screws with the brass bushings attached into the bottom cover.
The turntable is now reassembled.
If the motor continues to have no reaction to pressing the start/stop button after reconnecting the turntable to power and reattaching the platter, the issue is likely caused by a faulty motor.
For further technical assistance, please contact service@atus.com or one of the technicians at (330)686-2600 ext.5004
~Monday-Friday 8:00am to 5:00pm~
另外一个人完成了本指南。
