简介
This guide will show you how to locate, remove, and replace the buttons on the AT&T NVG510 modem. In the event that a button becomes stuck or your router becomes unresponsive when you press a button, you may need to replace it. This guide does require you to be able to operate a soldering iron carefully.
你所需要的
Place the router on one side so that the rubber stands are facing upward.
Remove the stands from the left corners only, relative to the AT&T logo if facing upright.
在这个步骤中使用的工具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove two screws using a 2.0 flathead screwdriver.
3等其他人完成本指南。
