跳转到主内容
AT&T CL4940 Number Pad Replacement and Cleaning
你所需要的
  1. AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: 步骤 1 中的图像 1,2 AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: 步骤 1 中的图像 2,2
    • Unplug your device before beginning disassembly.
    • Remove the phone line from the back cover of the device.
    • Remove the power cord from the side of the device.
    • Remove the phone cable from the side of the device.
  2. AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 2 中的图像 1,1
    • Remove the five 4mm X 10mm screws from the back cover of the device using a Phillips #1 screwdriver.
  3. AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 3 中的图像 1,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 3 中的图像 2,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 3 中的图像 3,3
    • Using a metal spudger, pry the white, plastic cover from the gray, plastic bottom. Start from below the keypad and work your way evenly around the device.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The internals of the device will be accessible once the white, plastic cover and grey, plastic bottom are separated.
  4. AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 4 中的图像 1,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 4 中的图像 2,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 4 中的图像 3,3
    • Remove the five 5mm X 5mm screws located on the yellow side of the motherboard using a Phillips #1 screwdriver.
    • Set the motherboard out of the way.
  5. AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 5 中的图像 1,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 5 中的图像 2,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 5 中的图像 3,3
    • Remove the two 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the 5mm X 6mm latch screw using the same screwdriver.
    • Remove the small, metal latch.
    • Remove the plastic plate previously secured by the screws and latch.
  6. AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 6 中的图像 1,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 6 中的图像 2,3 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 6 中的图像 3,3
    • Remove the remaining six 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the two 3mm X 6mm small number pad screws using the same screwdriver.
    • Grab the edge of the number pad board and peel it away from the screw posts.
    • Using a clean towel or cloth, move the number pad board away from the keys that lie below.
    • Set the number pad board out of the way for further disassembly.
  7. AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 7 中的图像 1,2 AT&T CL4940 Number Pad Replacement and Cleaning: 步骤 7 中的图像 2,2
    • Peel away the white, rubber mat and set it aside for cleaning.
    • Remove the main key pad and any remaining keys. Remember where each key is located for reassembly.
    • Clean the rubber mat with a damp paper towel to remove any dust or foreign substances.
    • Replace any broken or cracked keys.
结论
3等其他人完成本指南。
Nigel Mathias
于02/16/16注册
215 声望
撰写一个指南
团队
IUPUI, Team 2-2, Harley Spring 2016 IUPUI, Team 2-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S2G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 484
