跳转到主内容
AT&T NVG510 Button Replacement
你所需要的
  1. AT&T NVG510 Button Replacement, Reset and Wi-Fi Buttons: 步骤 1 中的图像 1,1
    • Place the router on one side so that the rubber stands are facing upward.
    • Remove the stands from the left corners only, relative to the AT&T logo if facing upright.
  2. AT&T NVG510 Button Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
  3. AT&T NVG510 Button Replacement: 步骤 3 中的图像 1,2 AT&T NVG510 Button Replacement: 步骤 3 中的图像 2,2
    • Pry open the case to reveal the board.
    • Some force may be required.
    • Take out the one screw located on the center-right area of the board.
  4. AT&T NVG510 Button Replacement: 步骤 4 中的图像 1,2 AT&T NVG510 Button Replacement: 步骤 4 中的图像 2,2
    • Lift the board slowly out of the case.
    • Be careful as to not damage the board.
  5. AT&T NVG510 Button Replacement: 步骤 5 中的图像 1,1
    • Locate the buttons to the right of the yellow ports along the edge of the board.
  6. AT&T NVG510 Button Replacement: 步骤 6 中的图像 1,3 AT&T NVG510 Button Replacement: 步骤 6 中的图像 2,3 AT&T NVG510 Button Replacement: 步骤 6 中的图像 3,3
    • Locate the silver points that connect the buttons to the board.
    • To release the buttons, use a soldering iron to heat up and melt the silver connecting points.
    • Avoid touching the solder to the board. Touch only the silver points.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 562
