简介
A step-by-step guide to removing and installing a vibration motor
你所需要的
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
在这个步骤中使用的工具:Heavy-Duty Spudger$4.99
The protective plate is now ready to be safely removed.
With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
Remove loosened plate and set aside.
With a flat metal spudger pry back the little metal clamps that hold the motor secure.
另外一个人完成了本指南。
