简介
Step-by-step guide in removing and replacing a faulty motherboard.
你所需要的
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
在这个步骤中使用的工具:Tweezers$4.99
With the metal tweezers gently remove the fabric covering the connection on bottom right
Using the heavy duty plastic spudger pry up on the connection ribbon.
在这个步骤中使用的工具:Heavy-Duty Spudger$4.99
The protective plate is now ready to be safely removed.
With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
Remove loosened plate and set aside.
3等其他人完成本指南。
1指南评论
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
Davy Jones - 回复
