跳转到主内容
ASUS ZenWatch Charging Cradle Circuit board Replacement
你所需要的
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: 步骤 1 中的图像 1,3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: 步骤 1 中的图像 2,3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: 步骤 1 中的图像 3,3
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: 步骤 2 中的图像 1,3 ASUS ZenWatch Charging Cradle Circuit board Replacement: 步骤 2 中的图像 2,3 ASUS ZenWatch Charging Cradle Circuit board Replacement: 步骤 2 中的图像 3,3
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
结论
Wayne McClure
于02/10/16注册
961 声望
创作了5篇指南
团队
USF Tampa, Team 1-3, Sullivan Spring 2016 USF Tampa, Team 1-3, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G3
4 名成员
创作了7篇指南
一条评论
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,871
