跳转到主内容
ASUS ZenPad S 8.0 Speakers Replacement
你所需要的
  1. ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: 步骤 1 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: 步骤 1 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement, Rear Cover Removal: 步骤 1 中的图像 3,3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 2 中的图像 1,2 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 2 中的图像 2,2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 3 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 3 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 3 中的图像 3,3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 4 中的图像 1,2 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 4 中的图像 2,2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: 步骤 5 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: 步骤 5 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement, Front Facing Camera: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 6 中的图像 1,1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: 步骤 7 中的图像 1,2 ASUS ZenPad S 8.0 Speakers Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 8 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 8 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 8 中的图像 3,3
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 9 中的图像 1,2 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 9 中的图像 2,2
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 10 中的图像 1,1
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 11 中的图像 1,1
    • Gently lift the motherboard from your device
  12. ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: 步骤 12 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: 步骤 12 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement, Daughter Board: 步骤 12 中的图像 3,3
    • To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
  13. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 13 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 13 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 13 中的图像 3,3
    • Using the tweezers gently pull off the tape over the ribbon cable
  14. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 14 中的图像 1,2 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 14 中的图像 2,2
    • Using the tweezers gently pull the ribbon cable out from from the connector.
  15. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 15 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 15 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 15 中的图像 3,3
    • Using the tweezers gently remove the connector from the yellow slot
  16. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 16 中的图像 1,2 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 16 中的图像 2,2
    • Cut the warranty tape connecting the daughter board to the metal plate under the battery
  17. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 17 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 17 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 17 中的图像 3,3
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
    • Gently lift the daughter board from the device
  18. ASUS ZenPad S 8.0 Speakers Replacement, Speakers: 步骤 18 中的图像 1,2 ASUS ZenPad S 8.0 Speakers Replacement, Speakers: 步骤 18 中的图像 2,2
    • Gently lift up the speaker to remove it from the device
  19. ASUS ZenPad S 8.0 Speakers Replacement: 步骤 19 中的图像 1,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 19 中的图像 2,3 ASUS ZenPad S 8.0 Speakers Replacement: 步骤 19 中的图像 3,3
    • Using the #00 Phillips head screwdriver, remove the 1.5mm screws
    • Gently lift up the second speaker to remove it from the device
结论
John Astfanous
于10/04/16注册
972 声望
创作了3篇指南
团队
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 960
