跳转到主内容
ASUS ZenPad S 8.0 Motherboard Replacement
你所需要的
  1. ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: 步骤 1 中的图像 1,3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: 步骤 1 中的图像 2,3 ASUS ZenPad S 8.0 Motherboard Replacement, Rear Cover Removal: 步骤 1 中的图像 3,3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 2 中的图像 1,2 ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 3 中的图像 1,3 ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 3 中的图像 2,3 ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 4 中的图像 1,2 ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: 步骤 5 中的图像 1,3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: 步骤 5 中的图像 2,3 ASUS ZenPad S 8.0 Motherboard Replacement, Front Facing Camera: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
  7. ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 ASUS ZenPad S 8.0 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
    • The removing of the ribbon cable is done in the same way as the front facing camera.
  8. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 8 中的图像 1,3 ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 8 中的图像 2,3 ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Using the tweezers remove the connector gently from the yellow slot
    • Gently peel up the tape until is is completely released from the motherboard
  9. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 9 中的图像 1,2 ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Cut the warranty tape connecting the motherboard to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
  11. ASUS ZenPad S 8.0 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Gently lift the motherboard from your device
结论
另外一个人完成了本指南。
Jessica Voss
于10/04/16注册
319 声望
撰写一个指南
团队
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G2
4 名成员
创作了5篇指南
2条评论
Where can I buy a spare motherboard for this device.
Partha Tripathy - 回复
Where are the motherboard sold and how do I purchase micro USB ports
Xibu Zhang - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 2,599
