跳转到主内容
ASUS ZenPad S 8.0 Front Facing Camera Replacement
你所需要的
  1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 步骤 1 中的图像 1,3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 步骤 1 中的图像 2,3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: 步骤 1 中的图像 3,3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 2 中的图像 1,2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 3 中的图像 1,3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 3 中的图像 2,3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 4 中的图像 1,2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 步骤 5 中的图像 1,3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 步骤 5 中的图像 2,3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Front Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
结论
John Astfanous
于10/04/16注册
987 声望
创作了3篇指南
团队
USF Tampa, Team 2-2, Cagle Fall 2016 USF Tampa, Team 2-2, Cagle Fall 2016 的会员
USFT-CAGLE-F16S2G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 1,333
