跳转到主内容
ASUS X552LAV-BBI5N08 Hard Drive Replacement
你所需要的
  1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 2 中的图像 1,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 2 中的图像 2,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 4 中的图像 1,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 4 中的图像 2,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 5 中的图像 1,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 5 中的图像 2,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 6 中的图像 1,2 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
  7. ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 7 中的图像 1,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 7 中的图像 2,3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
结论
Jason Vo
于02/15/18注册
857 声望
创作了5篇指南
团队
USF Tampa, Team S17-G1, Boczar Spring 2018 USF Tampa, Team S17-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 296
