跳转到主内容
ASUS X552LAV-BBI5N08 CD Drive Replacement
你所需要的
  1. ASUS X552LAV-BBI5N08 CD Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 2 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 2 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 2 中的图像 3,3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 CD Drive Replacement, CD Drive: 步骤 3 中的图像 1,1
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 4 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 4 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 4 中的图像 3,3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 5 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 5 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 6 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 6 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 6 中的图像 3,3
    • Use Tri-wing Y1 screwdriver to remove seven 4mm screws from battery area.
    • Use opening tool to split keyboard from base of the laptop.
    • Make sure to start from one end and go around the edges.
  7. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 7 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 7 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 7 中的图像 3,3
    • Flip laptop to sit on its bottom.
    • Lift keyboard up by the front edge
  8. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 8 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 8 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 8 中的图像 3,3
    • Flip up the small locking flap for the two ZIF connectors.
    • Unplug the connectors that are keeping the keyboard connected.
  9. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 9 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 9 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 9 中的图像 3,3
    • Flip up the locking flap for the ZIF connector.
    • Unplug the connector that is keeping the keyboard connected.
  10. ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 10 中的图像 1,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 10 中的图像 2,3 ASUS X552LAV-BBI5N08 CD Drive Replacement: 步骤 10 中的图像 3,3
    • Remove keyboard from laptop.
    • Remove two 4mm screws around CD drive
    • Slide the CD drive out to the right to remove it.
结论
Jason Vo
于02/15/18注册
857 声望
创作了5篇指南
团队
USF Tampa, Team S17-G1, Boczar Spring 2018 USF Tampa, Team S17-G1, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 240
