跳转到主内容
ASUS X550LB-DS71 Fan Replacement
你所需要的
  1. ASUS X550LB-DS71 Fan Replacement, Fan: 步骤 1 中的图像 1,3 ASUS X550LB-DS71 Fan Replacement, Fan: 步骤 1 中的图像 2,3 ASUS X550LB-DS71 Fan Replacement, Fan: 步骤 1 中的图像 3,3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Fan Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
  3. ASUS X550LB-DS71 Fan Replacement: 步骤 3 中的图像 1,3 ASUS X550LB-DS71 Fan Replacement: 步骤 3 中的图像 2,3 ASUS X550LB-DS71 Fan Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Fan Replacement: 步骤 4 中的图像 1,2 ASUS X550LB-DS71 Fan Replacement: 步骤 4 中的图像 2,2
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
  5. ASUS X550LB-DS71 Fan Replacement: 步骤 5 中的图像 1,2 ASUS X550LB-DS71 Fan Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
  6. ASUS X550LB-DS71 Fan Replacement: 步骤 6 中的图像 1,2 ASUS X550LB-DS71 Fan Replacement: 步骤 6 中的图像 2,2
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
  7. ASUS X550LB-DS71 Fan Replacement: 步骤 7 中的图像 1,3 ASUS X550LB-DS71 Fan Replacement: 步骤 7 中的图像 2,3 ASUS X550LB-DS71 Fan Replacement: 步骤 7 中的图像 3,3
    • Flip the motherboard to show the underside.
    • Locate the square fan connection attached to the motherboard.
    • Disconnect it using the tweezers (blunt).
  8. ASUS X550LB-DS71 Fan Replacement: 步骤 8 中的图像 1,1
    • Remove the black tape from the fan as seen in the marked location.
    • At this point, the fan is now disconnected from the motherboard.
结论
另外一个人完成了本指南。
Nathan Dyer
于09/25/17注册
550 声望
创作了5篇指南
团队
USF Tampa, Team S16-G1, Eyestone Fall 2017 USF Tampa, Team S16-G1, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 857
