跳转到主内容
ASUS X533SA-BHCLN10 Optical Disc Drive Replacement
你所需要的
  1. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 1,2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 步骤 2 中的图像 1,2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 步骤 2 中的图像 2,2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 步骤 3 中的图像 1,2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 步骤 3 中的图像 2,2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
  4. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 4 中的图像 1,2 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 4 中的图像 2,2
    • Remove all 3 screws with the screwdriver.
    • The top left screw is 5.5 mm and the bottom two screws are 2.5 mm.
  5. ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 步骤 5 中的图像 1,3 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 步骤 5 中的图像 2,3 ASUS X533SA-BHCLN10 Optical Disc Drive Replacement: 步骤 5 中的图像 3,3
    • Gently, push the optical drive part from inside to remove the drive from the motherboard socket.
    • While replacing, make sure the optical drive is connected to the socket of the motherboard (denoted by the red rectangle).
结论
Edmund Lee
于09/26/17注册
473 声望
创作了4篇指南
团队
USF Tampa, Team S13-G3, Boczar Fall 2017 USF Tampa, Team S13-G3, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 206
