跳转到主内容
ASUS X533SA-BHCLN10 LCD Screen Replacement
你所需要的
视频概述
  1. ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,2 ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Power off laptop.
    • Flip over the laptop so the model stickers are pointing towards the ceiling, and the back of the laptop is facing you.
  2. ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 2 中的图像 1,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 2 中的图像 2,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Carefully insert a plastic opening tool into the top edge of the plastic cover. Slowly run the tool along the top edge to allow several small plastic clips to release.
    • Lift the plastic cover off and set it aside.
  3. ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 3 中的图像 1,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 3 中的图像 2,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers, remove the (2) two magnetic tabs covering the screws on the screen.
  4. ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 4 中的图像 1,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 4 中的图像 2,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Use a JIS #0 screwdriver to remove the two 4.5mm screws.
  5. ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 5 中的图像 1,2 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening tool under the edge of the laptop lid.
    • Carefully pop out the sides of the laptop by running the plastic opening tool along the edge.
  6. ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 6 中的图像 1,2 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Use a JIS #0 screwdriver to unscrew the four 3.5mm screws.
  7. ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 7 中的图像 1,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 7 中的图像 2,3 ASUS X533SA-BHCLN10 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Carefully lift up the LCD screen.
    • Carefully remove the cable connecting the LCD to the laptop by popping up the white clip on the laptop and sliding the connector out.
结论
Spencer Lee
于11/01/18注册
283 声望
创作了2篇指南
团队
IUPUI, Team S2-G4, Harley Fall 2018 IUPUI, Team S2-G4, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S2G4
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 635
