跳转到主内容
ASUS X533SA-BHCLN10 Hard Drive Replacement
你所需要的
视频概述
  1. ASUS X533SA-BHCLN10 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 ASUS X533SA-BHCLN10 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Hard Drive Replacement: 步骤 2 中的图像 1,2 ASUS X533SA-BHCLN10 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Hard Drive Replacement: 步骤 3 中的图像 1,2 ASUS X533SA-BHCLN10 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
  4. ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,3 ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,3 ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • The hard drive is closest to the screen, enclosed in a metal plate.
    • Remove all screws holding the hard drive in place.
  5. ASUS X533SA-BHCLN10 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • After all screws are removed, carefully disconnect the hard drive and slide it out.
  6. ASUS X533SA-BHCLN10 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove screws from the metal plate enclosing hard drive and enclose replacement hard drive in metal plate.
结论
团队
USF Tampa, Team S13-G3, Boczar Fall 2017 USF Tampa, Team S13-G3, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 461
