简介
In this guide we will be going through the process of replacing the battery. The process is not too hard and requires to first remove a number of screws. Follow the instructions carefully and diligently to be sure to not make any mistakes in the process. Changing the battery is a very simple task and with this guide you should easily replace it.
你所需要的
Turn over the laptop on the back panel.
Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
3等其他人完成本指南。
