跳转到主内容
ASUS X502CA Wi-Fi Card Replacement
你所需要的
  1. ASUS X502CA Wi-Fi Card Replacement, Palm Rest with Keyboard and Touch Pad: 步骤 1 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Wi-Fi Card Replacement, Hard Drive: 步骤 5 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
  6. ASUS X502CA Wi-Fi Card Replacement: 步骤 6 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 6 中的图像 2,2
    • Lift the hard drive and attached bracket up and out.
  7. ASUS X502CA Wi-Fi Card Replacement: 步骤 7 中的图像 1,3 ASUS X502CA Wi-Fi Card Replacement: 步骤 7 中的图像 2,3 ASUS X502CA Wi-Fi Card Replacement: 步骤 7 中的图像 3,3
    • Remove the four 5mm Phillips #0 screws attaching the bracket to the hard drive.
    • There are 2 screws on each side.
  8. ASUS X502CA Wi-Fi Card Replacement, LED Board: 步骤 8 中的图像 1,3 ASUS X502CA Wi-Fi Card Replacement, LED Board: 步骤 8 中的图像 2,3 ASUS X502CA Wi-Fi Card Replacement, LED Board: 步骤 8 中的图像 3,3
    • Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
  9. ASUS X502CA Wi-Fi Card Replacement: 步骤 9 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 9 中的图像 2,2
    • Use 1 or 2 plastic opening tools to push down the small black plastic clips.
    • Pull the board up and out.
  10. ASUS X502CA Wi-Fi Card Replacement, Left I/O Board: 步骤 10 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement, Left I/O Board: 步骤 10 中的图像 2,2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  11. ASUS X502CA Wi-Fi Card Replacement: 步骤 11 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 11 中的图像 2,2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  12. ASUS X502CA Wi-Fi Card Replacement: 步骤 12 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 12 中的图像 2,2
    • Slightly pull the unhinged screen up to free the board and remove it.
  13. ASUS X502CA Wi-Fi Card Replacement, Battery: 步骤 13 中的图像 1,1
    • Next, locate the battery in the front of laptop (closest to you).
  14. ASUS X502CA Wi-Fi Card Replacement: 步骤 14 中的图像 1,1
    • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
    • If battery is not unplugged, motherboard may shock you.
  15. ASUS X502CA Wi-Fi Card Replacement: 步骤 15 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 15 中的图像 2,2
    • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
    • Once you have removed all six screws carefully lift the battery out and dispose.
    • Each screw is 50 mm in length and 15 mm in diameter.
  16. ASUS X502CA Wi-Fi Card Replacement, Motherboard: 步骤 16 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement, Motherboard: 步骤 16 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the last five 5mm screws holding the motherboard down.
    • These screws will be marked by diamonds next to the screw holes.
  17. ASUS X502CA Wi-Fi Card Replacement: 步骤 17 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement: 步骤 17 中的图像 2,2
    • Use the plastic opening tool to unclip the two wires from the Wi-Fi card that are connected to the motherboard.
  18. ASUS X502CA Wi-Fi Card Replacement: 步骤 18 中的图像 1,3 ASUS X502CA Wi-Fi Card Replacement: 步骤 18 中的图像 2,3 ASUS X502CA Wi-Fi Card Replacement: 步骤 18 中的图像 3,3
    • Flip the motherboard over and use the plastic opening tool to unplug the black and red wires from the motherboard.
  19. ASUS X502CA Wi-Fi Card Replacement: 步骤 19 中的图像 1,1
    • Pull up on the motherboard and take it out.
  20. ASUS X502CA Wi-Fi Card Replacement, Wi-Fi Card: 步骤 20 中的图像 1,2 ASUS X502CA Wi-Fi Card Replacement, Wi-Fi Card: 步骤 20 中的图像 2,2
    • Take out the 2.5mm PH #0 screw located on the top of the Wi-Fi card.
    • Lift the card up and pull it out.
结论
团队
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G6
3 名成员
创作了5篇指南
一条评论
Thank you
What type of card should we buy? We have to be ready with the replacement to start to take the parts out.
Can you post a picture of the card so we can see the slot and read what is written on it. I know you have 2 pictures but the red circle cover the writing.
Do you know the slot type of that card? Is it PCI-E slot ?
Do you know if that computer can accept 802.11ac or 802.11ax card ?
Can you post a link to the card that you used as replacement or another compatible card?
marcos - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 608
