跳转到主内容
ASUS X502CA Screen Replacement
你所需要的
  1. ASUS X502CA Screen Replacement, Screen: 步骤 1 中的图像 1,2 ASUS X502CA Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Remove plastic square covers on both bottom corners exposing the screws below using tweezers.
    • Remove the screws under the plastic square covers, using a Phillips #00 screwdriver.
    • Screws are black, 50mm in lenght with a 20mm diameter.
  2. ASUS X502CA Screen Replacement: 步骤 2 中的图像 1,2 ASUS X502CA Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the trim from the monitor by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
  3. ASUS X502CA Screen Replacement: 步骤 3 中的图像 1,2 ASUS X502CA Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the four phillips screws (two on top and two on bottom) using the Phillips #00 screwdriver.
    • The screws are black, 45mm long and 15mm in diameter with a philips head
  4. ASUS X502CA Screen Replacement: 步骤 4 中的图像 1,2 ASUS X502CA Screen Replacement: 步骤 4 中的图像 2,2
    • Pop the screen out from the top and lay flat on the keyboard.
    • Do not pull screen away from keyboard, as it is still attached by a wire at the bottom.
  5. ASUS X502CA Screen Replacement: 步骤 5 中的图像 1,2 ASUS X502CA Screen Replacement: 步骤 5 中的图像 2,2
    • Peel off the clear tape that is securing the video cable connector using your fingers or tweezers.
  6. ASUS X502CA Screen Replacement: 步骤 6 中的图像 1,2 ASUS X502CA Screen Replacement: 步骤 6 中的图像 2,2
    • Unplug the screen using tweezers.
  7. ASUS X502CA Screen Replacement: 步骤 7 中的图像 1,1
    • Replace the damage screen with a new one.
    • Replacing the bezel trim requires the bottom to be inside the ends of the hinge cover. Be careful not to break the bezel when doing this.
    • Removing the hinge cover has a chance of breaking the tabs that hold it on. Remove it carefully.
结论
3等其他人完成本指南。
Anthony Taylor
于01/28/15注册
354 声望
创作了2篇指南
团队
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S14G1
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 3,317
