跳转到主内容
ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
你所需要的
  1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement, Palm Rest with Keyboard and Touch Pad: 步骤 1 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 步骤 2 中的图像 1,1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 步骤 3 中的图像 1,2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 步骤 3 中的图像 2,2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 步骤 4 中的图像 1,2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: 步骤 4 中的图像 2,2
    • Lift Palm Rest away.
    • Replace with new palm rest.
结论
5等其他人完成本指南。
团队
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S14G1
5 名成员
创作了5篇指南
一条评论
there is no reason to disassemble the top-half of the laptop.
seanwilson684 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,885
