跳转到主内容
ASUS X502CA Motherboard Replacement
你所需要的
  1. ASUS X502CA Motherboard Replacement, Palm Rest with Keyboard and Touch Pad: 步骤 1 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Motherboard Replacement: 步骤 2 中的图像 1,1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Motherboard Replacement: 步骤 3 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 3 中的图像 2,2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Motherboard Replacement: 步骤 4 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,2 ASUS X502CA Motherboard Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
  6. ASUS X502CA Motherboard Replacement: 步骤 6 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 6 中的图像 2,2
    • Lift the hard drive and attached bracket up and out.
  7. ASUS X502CA Motherboard Replacement: 步骤 7 中的图像 1,3 ASUS X502CA Motherboard Replacement: 步骤 7 中的图像 2,3 ASUS X502CA Motherboard Replacement: 步骤 7 中的图像 3,3
    • Remove the four 5mm Phillips #0 screws attaching the bracket to the hard drive.
    • There are 2 screws on each side.
  8. ASUS X502CA Motherboard Replacement, LED Board: 步骤 8 中的图像 1,3 ASUS X502CA Motherboard Replacement, LED Board: 步骤 8 中的图像 2,3 ASUS X502CA Motherboard Replacement, LED Board: 步骤 8 中的图像 3,3
    • Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
  9. ASUS X502CA Motherboard Replacement: 步骤 9 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use 1 or 2 plastic opening tools to push down the small black plastic clips.
    • Pull the board up and out.
  10. ASUS X502CA Motherboard Replacement, Left I/O Board: 步骤 10 中的图像 1,2 ASUS X502CA Motherboard Replacement, Left I/O Board: 步骤 10 中的图像 2,2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  11. ASUS X502CA Motherboard Replacement: 步骤 11 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 11 中的图像 2,2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  12. ASUS X502CA Motherboard Replacement: 步骤 12 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 12 中的图像 2,2
    • Slightly pull the unhinged screen up to free the board and remove it.
  13. ASUS X502CA Motherboard Replacement, Battery: 步骤 13 中的图像 1,1
    • Next, locate the battery in the front of laptop (closest to you).
  14. ASUS X502CA Motherboard Replacement: 步骤 14 中的图像 1,1
    • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
    • If battery is not unplugged, motherboard may shock you.
  15. ASUS X502CA Motherboard Replacement: 步骤 15 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 15 中的图像 2,2
    • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
    • Once you have removed all six screws carefully lift the battery out and dispose.
    • Each screw is 50 mm in length and 15 mm in diameter.
  16. ASUS X502CA Motherboard Replacement, Motherboard: 步骤 16 中的图像 1,2 ASUS X502CA Motherboard Replacement, Motherboard: 步骤 16 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the last five 5mm screws holding the motherboard down.
    • These screws will be marked by diamonds next to the screw holes.
  17. ASUS X502CA Motherboard Replacement: 步骤 17 中的图像 1,2 ASUS X502CA Motherboard Replacement: 步骤 17 中的图像 2,2
    • Use the plastic opening tool to unclip the two wires from the Wi-Fi card that are connected to the motherboard.
  18. ASUS X502CA Motherboard Replacement: 步骤 18 中的图像 1,3 ASUS X502CA Motherboard Replacement: 步骤 18 中的图像 2,3 ASUS X502CA Motherboard Replacement: 步骤 18 中的图像 3,3
    • Flip the motherboard over and use the plastic opening tool to unplug the black and red wires from the motherboard.
  19. ASUS X502CA Motherboard Replacement: 步骤 19 中的图像 1,1
    • Pull up on the motherboard and take it out.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 565
