跳转到主内容
ASUS X502CA Left I/O Board Replacement
你所需要的
  1. ASUS X502CA Left I/O Board Replacement, Palm Rest with Keyboard and Touch Pad: 步骤 1 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Left I/O Board Replacement: 步骤 2 中的图像 1,1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Left I/O Board Replacement: 步骤 3 中的图像 1,2 ASUS X502CA Left I/O Board Replacement: 步骤 3 中的图像 2,2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Left I/O Board Replacement: 步骤 4 中的图像 1,2 ASUS X502CA Left I/O Board Replacement: 步骤 4 中的图像 2,2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Left I/O Board Replacement, Left I/O Board: 步骤 5 中的图像 1,2 ASUS X502CA Left I/O Board Replacement, Left I/O Board: 步骤 5 中的图像 2,2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  6. ASUS X502CA Left I/O Board Replacement: 步骤 6 中的图像 1,2 ASUS X502CA Left I/O Board Replacement: 步骤 6 中的图像 2,2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  7. ASUS X502CA Left I/O Board Replacement: 步骤 7 中的图像 1,2 ASUS X502CA Left I/O Board Replacement: 步骤 7 中的图像 2,2
    • Slightly pull the unhinged screen up to free the board and remove it.
结论
团队
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 182
