跳转到主内容
ASUS X502CA LED Board Replacement
你所需要的
  1. ASUS X502CA LED Board Replacement, Palm Rest with Keyboard and Touch Pad: 步骤 1 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA LED Board Replacement: 步骤 2 中的图像 1,1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA LED Board Replacement: 步骤 3 中的图像 1,2 ASUS X502CA LED Board Replacement: 步骤 3 中的图像 2,2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA LED Board Replacement: 步骤 4 中的图像 1,2 ASUS X502CA LED Board Replacement: 步骤 4 中的图像 2,2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA LED Board Replacement, LED Board: 步骤 5 中的图像 1,3 ASUS X502CA LED Board Replacement, LED Board: 步骤 5 中的图像 2,3 ASUS X502CA LED Board Replacement, LED Board: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
  6. ASUS X502CA LED Board Replacement: 步骤 6 中的图像 1,2 ASUS X502CA LED Board Replacement: 步骤 6 中的图像 2,2
    • Use 1 or 2 plastic opening tools to push down the small black plastic clips.
    • Pull the board up and out.
结论
另外一个人完成了本指南。
Beau Raymond
于11/06/18注册
103 声望
撰写一个指南
团队
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 197
