跳转到主内容
ASUS X502CA Fan Replacement
你所需要的
  1. ASUS X502CA Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove:
    • Eight 9 mm screws.
    • Four 5 mm screws.
  2. ASUS X502CA Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Fan Replacement: 步骤 3 中的图像 1,1
    • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
  4. ASUS X502CA Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard cover panel.
  5. ASUS X502CA Fan Replacement: 步骤 5 中的图像 1,1
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • If these are not unplugged, the motherboard may shock you.
  6. ASUS X502CA Fan Replacement: 步骤 6 中的图像 1,1
    • Disconnect the remaining connectors using tweezers or your finger nails.
  7. ASUS X502CA Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the six 5 mm screws using the Phillips #00 screwdriver.
  8. ASUS X502CA Fan Replacement: 步骤 8 中的图像 1,1
    • Flip the motherboard over and away from the screen.
  9. ASUS X502CA Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  10. ASUS X502CA Fan Replacement: 步骤 10 中的图像 1,1
    • Unplug the fan's power connector using tweezers or your fingernails.
  11. ASUS X502CA Fan Replacement: 步骤 11 中的图像 1,1
    • Peel off the marked strip using your fingers.
  12. ASUS X502CA Fan Replacement: 步骤 12 中的图像 1,1
    • Lift the fan up and away from the motherboard.
结论
6等其他人完成本指南。
David Conner
于03/03/15注册
292 声望
创作了2篇指南
团队
Clemson, Team 14-1, Shirley Winter 2015 Clemson, Team 14-1, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S14G1
5 名成员
创作了5篇指南
2条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 7,835
