简介
Use this guide to help you replace a broken or damaged fan that may be causing overheating issues and other problems with your laptop. Don't forget to keep track of all your screws.
你所需要的
Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
Lift up the black lock holding the ribbon.
Using the blue tab, pull out the ribbon.
即将完成!
结论
另外一个人完成了本指南。
