跳转到主内容
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  1. Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  2. Slide the disk drive out of the device.
    • Slide the disk drive out of the device.
  3. Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive. Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive. Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  4. Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard. Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  5. Unscrew and remove the marked screws.
    • Unscrew and remove the marked screws.
  6. Separate the connectors.
    • Separate the connectors.
  7. Remove the motherboard from the device. Remove the motherboard from the device.
    • Remove the motherboard from the device.
  8. Unscrew the six screws using the Phillips #0 Screwdriver.
    • Unscrew the six screws using the Phillips #0 Screwdriver.
  9. Unplug the fan's wires from the motherboard.
    • Unplug the fan's wires from the motherboard.
  10. Remove the fan from the motherboard. Remove the fan from the motherboard.
    • Remove the fan from the motherboard.
结论
Ryan Pritchard
于2018年09月21日注册
105 信誉积分
撰写一个指南
一条评论
First step is wrong; attempting to prise out the keyboard will damage it. First step should be to remove the screws which hold in the keyboard.
Kate Gregory - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 8
总计 395
