跳转到主内容
ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
你所需要的
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: 步骤 1 中的图像 1,1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 步骤 2 中的图像 1,1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: 步骤 3 中的图像 1,2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: 步骤 3 中的图像 2,2
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 步骤 4 中的图像 1,2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 步骤 4 中的图像 2,2
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: 步骤 5 中的图像 1,1
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
结论
Mark Fanelli
于04/09/19注册
97 声望
撰写一个指南
团队
IUPUI, Team S1-G2, Hovde Spring 2019 IUPUI, Team S1-G2, Hovde Spring 2019 的会员
IUPUI-HOVDE-S19S1G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 425
