简介
Random access memory aka RAM, is used for a short-term storage for your laptop. Memory size can vary for personal needs. This step will help you if you need to replace your RAM or if you want to increase your RAM size in your ASUS Vivobook Q301LA-BSI5T17 laptop.
你所需要的
Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
Lift the perforated metal cover up from the motherboard to expose the memory cards.
即将完成!
结论
