跳转到主内容
ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement
你所需要的
  1. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Back Case Housing: 步骤 1 中的图像 1,1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: 步骤 2 中的图像 1,1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Fan: 步骤 3 中的图像 1,1
    • Remove three 5mm Phillips #1 screws that are holding the fan in place.
  4. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: 步骤 4 中的图像 1,2 ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: 步骤 4 中的图像 2,2
    • Carefully unplug the fan cable from the motherboard using a spudger or plastic opening tool.
  5. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: 步骤 5 中的图像 1,2 ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: 步骤 5 中的图像 2,2
    • Carefully use your hands to remove the fan by pulling it from the heatsink housing.
    • Do not use excessive force; there is a potential to break the plastic.
结论
Amrinder Singh
于04/09/19注册
277 声望
创作了3篇指南
团队
IUPUI, Team S1-G2, Hovde Spring 2019 IUPUI, Team S1-G2, Hovde Spring 2019 的会员
IUPUI-HOVDE-S19S1G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 279
