跳转到主内容
ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
你所需要的
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 2 中的图像 1,2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 3 中的图像 1,2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 4 中的图像 1,2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 5 中的图像 1,2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
结论
3等其他人完成本指南。
David Nguyen
于05/14/21注册
202 声望
撰写一个指南
团队
一条评论
I replaced the original sata into a ssd but it doesnt boot to windows. It gets stuck in bios. The ssd has an os already. It appears in the storage section but not in the boot list. I have already tried to boot the ssd to my computer and it works.
Christusjohn Leoncio L Salvani - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 14
过去 30 天: 43
总计 1,693
