简介
It is rare for LED boards to fail, so be sure to check that the function that is supposed to be lighting the LED is working correctly before suspecting a faulty LED.
Note that the battery has been removed for the purpose of visual clarity in this guide, but it is not necessary in order to replace the LED board. Doing so does make removing the ribbon cable slightly easier.
你所需要的
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Using a spudger, lift up the plug connecting the battery to the motherboard.
Disconnect the ribbon cable connecting the LED daughterboard and the motherboard by lifting the white tab on the LED side of the cable.
