跳转到主内容
ASUS VivoBook S400C Hard Drive Replacement
你所需要的
  1. ASUS VivoBook S400C Hard Drive Replacement, Remove the Bottom Cover: 步骤 1 中的图像 1,1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Hard Drive Replacement: 步骤 2 中的图像 1,2 ASUS VivoBook S400C Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Hard Drive Replacement, Disconnect the Battery: 步骤 3 中的图像 1,1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Hard Drive Replacement, Battery: 步骤 4 中的图像 1,1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Pull left and lift out the hard drive.
结论
Tiana Curry
于10/18/19注册
85 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 2,011
