跳转到主内容
ASUS VivoBook S300C Hard Drive Replacement
你所需要的
  1. ASUS VivoBook S300C Hard Drive Replacement, Remove the bottom cover: 步骤 1 中的图像 1,1
    • Remove the 10 screws on the back cover.
    • Some screws are missing from this system. You should take your own notes to make sure you put the correct screws in during reassembly.
  2. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive cable: 步骤 2 中的图像 1,1
    • Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • I am also missing screws here. Take your own notes to avoid misplacing screws during reassembly. They should all be the same length.
  3. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: 步骤 3 中的图像 1,2 ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: 步骤 3 中的图像 2,2
    • Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Reassemble the laptop by following the steps in reverse order. This is my first guide, so let me know what I did wrong so I can fix it.
结论
4等其他人完成本指南。
Cameron
于12/02/15注册
10,353 声望
撰写一个指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,506篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 3,487
