跳转到主内容
ASUS VivoBook Flip TP501U RAM Replacement
你所需要的
  1. ASUS VivoBook Flip TP501U RAM Replacement, Keyboard Panel: 步骤 1 中的图像 1,2 ASUS VivoBook Flip TP501U RAM Replacement, Keyboard Panel: 步骤 1 中的图像 2,2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U RAM Replacement: 步骤 2 中的图像 1,1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U RAM Replacement: 步骤 3 中的图像 1,1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U RAM Replacement, WiFi Card: 步骤 4 中的图像 1,3 ASUS VivoBook Flip TP501U RAM Replacement, WiFi Card: 步骤 4 中的图像 2,3 ASUS VivoBook Flip TP501U RAM Replacement, WiFi Card: 步骤 4 中的图像 3,3
    • Locate and remove the single 3.17 mm screw holding in the WiFi card suing a Phillips #00 driver.
    • Disconnect the card from the motherboard by pulling down on the card.
    • Unplug the two black and white wires from the bottom of the card. They should pop off.
  5. ASUS VivoBook Flip TP501U RAM Replacement, RAM: 步骤 5 中的图像 1,2 ASUS VivoBook Flip TP501U RAM Replacement, RAM: 步骤 5 中的图像 2,2
    • Unscrew the five 4.8mm Phillips #00 screws holding in the hard drive mounting bracket.
    • Slide the mounting bracket towards the battery to disconnect the hard drive from the motherboard.
  6. ASUS VivoBook Flip TP501U RAM Replacement: 步骤 6 中的图像 1,3 ASUS VivoBook Flip TP501U RAM Replacement: 步骤 6 中的图像 2,3 ASUS VivoBook Flip TP501U RAM Replacement: 步骤 6 中的图像 3,3
    • Detach the white ribbon cable.
    • Detach the black ribbon cable.
    • Disconnect the battery from the motherboard.
    • Disconnect the motherboard power cable.
  7. ASUS VivoBook Flip TP501U RAM Replacement: 步骤 7 中的图像 1,2 ASUS VivoBook Flip TP501U RAM Replacement: 步骤 7 中的图像 2,2
    • Remove the ten 4.8mm Phillips #00 screws.
    • There will be one more wire still attaching the motherboard to the chassis. Do not disconnect it, but just remove the motherboard from the case.
  8. ASUS VivoBook Flip TP501U RAM Replacement: 步骤 8 中的图像 1,1
    • Flip over the motherboard to see the underside.
    • Depress the clips keeping the RAM in place and remove the current RAM stick.
结论
另外一个人完成了本指南。
一条评论
does this laptop support ddr4 ram? i have looked everywhere and it doesnt give me a clear answer.
Julius Inta (juliuswhat) - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 28
总计 1,410
