跳转到主内容
ASUS VivoBook Flip TP501U Keyboard Panel Replacement
你所需要的
  1. ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: 步骤 1 中的图像 1,2 ASUS VivoBook Flip TP501U Keyboard Panel Replacement, Keyboard Panel: 步骤 1 中的图像 2,2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: 步骤 2 中的图像 1,1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Keyboard Panel Replacement: 步骤 3 中的图像 1,1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 903
