跳转到主内容
ASUS Vivo AiO V241IC HDD and RAM Replacement
你所需要的
  1. ASUS Vivo AiO V241IC HDD and RAM Replacement, Remove 4 screws: 步骤 1 中的图像 1,1
    • Power off your device
    • Place it horizontaly on the stable ground
    • Remove 4 screws at the bottom of the display
    • Take grey panel from the sides and pull it up
    • Be careful to pulling up - there are two connectors, which goes from display to motherboard. You can safelly lift display for 5-7 cm (like on the photo)
  2. ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: 步骤 2 中的图像 1,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: 步骤 2 中的图像 2,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: 步骤 2 中的图像 3,3
    • After disconnecting two connectors from the motherboard you can lift display up
    • There is an also connector to display from motherboard and do not hurry to lift up display
    • There is no metal cover from the motherboard on this photo
  3. ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: 步骤 3 中的图像 1,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: 步骤 3 中的图像 2,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: 步骤 3 中的图像 3,3
    • Now you can see motherboard, covered up by metal cover
    • HDD - on the left side. Remove screws and pull HDD-case
  4. ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: 步骤 4 中的图像 1,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: 步骤 4 中的图像 2,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: 步骤 4 中的图像 3,3
    • Remove screws from the metal cover and pull up - you can see the motherboard
    • RAM - 2 Slots, DDR4 2400 Mhz
  5. ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: 步骤 5 中的图像 1,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: 步骤 5 中的图像 2,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard front side overview: 步骤 5 中的图像 3,3
    • Here you can find more details of the V241ICR-R rev 2.0 mainboard.
    • This refers to V241ICGK-BA111T model of the PC
  6. ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: 步骤 6 中的图像 1,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: 步骤 6 中的图像 2,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Accessing SSD slot: 步骤 6 中的图像 3,3
    • Remove all marked screws to get to the other side of the mainboard.
    • Dont forget the central one, the Fan and all the cables before lifting the MB. It goes up easy but may be some sticky glue below.
  7. ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: 步骤 7 中的图像 1,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: 步骤 7 中的图像 2,3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Motherboard back side overview: 步骤 7 中的图像 3,3
    • Here you can find NGFF M.2 (key M) slot for 2280 size SSD.
    • Install any AHCI (mSATA) SSD. Modules with both keys B+M are OK. Note that NVME and other PCI-E/USB modules are NOT supported.
    • You may need an extra srew to fix your new SSD in the slot.
    • Reasseble the system in reverse order
结论
15等其他人完成本指南。
34指南评论
Приветствую, Константин. Спасибо за подробный отчет по разбору. Сейчас стоит вопрос о приобретении такого же моноблока, однако есть важный нюанс, который меня интересует. Планирую сразу поставить SSD, но 1ТБ жесткий диск хотелось бы оставить как второй накопитель. На сайте производителя заявлено, что в топовой комплектации наряду с 1Тб HDD установлен ещё и SSD стандарта M2 (https://www.asus.com/All-in-One-PCs/Vivo...). У вас на 2 шаге, третье фото видна сама материнская плата, однако не совсем понятно есть ли на ней такой разъем. Есть что-то похожее на него в верхнем правом углу, как раз где вы красным прямоугольником обозначили область шлейфа дисплея. Можете выложить это фото без прямоугольника в хорошем разрешении или отправить мне на почту rf_c(собака)mail.ru. Буду очень признателен!
Viktor Che - 回复
могу на днях посмотреть если еще актуально
Konstantin Epikhin -
инструкция хорошая, но, к сожалению, для меня не полная. после снятия крышки с материнской платы выяснилось, что память накрыта дополнительной железной крышечкой. пока думаю как ее снимать.
Roman Vasilenko - 回复
вы имеете ввиду крышку на материнской плате? сама память у меня не была ничем не прикрыта
разобрался. с боков крышки есть вырезы, куда можно просунуть отвертку. надо потянуть вверх - она отщелкивается (винтов нет).
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 64
过去 30 天: 324
总计 27,713
