简介
Need to access the internals of your ASUS VG248? Here's a guide that shows how to remove the frame and open the display.
你所需要的
Four rubbery covers hide four screws in the rear of the monitor.
Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
23等其他人完成本指南。
11指南评论
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
You could yes, but be very careful NOT to introduce dust into the panel!
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
Piero -
