跳转到主内容
加入维修社区 - 创建账户
ASUS UX50V-RX05 Case Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. ASUS UX50V-RX05 Case Removal, Keyboard: 步骤 1 中的图像 1,3 ASUS UX50V-RX05 Case Removal, Keyboard: 步骤 1 中的图像 2,3 ASUS UX50V-RX05 Case Removal, Keyboard: 步骤 1 中的图像 3,3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
  2. ASUS UX50V-RX05 Case Removal: 步骤 2 中的图像 1,2 ASUS UX50V-RX05 Case Removal: 步骤 2 中的图像 2,2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
  3. ASUS UX50V-RX05 Case Removal: 步骤 3 中的图像 1,2 ASUS UX50V-RX05 Case Removal: 步骤 3 中的图像 2,2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
  4. ASUS UX50V-RX05 Case Removal, Case Removal: 步骤 4 中的图像 1,3 ASUS UX50V-RX05 Case Removal, Case Removal: 步骤 4 中的图像 2,3 ASUS UX50V-RX05 Case Removal, Case Removal: 步骤 4 中的图像 3,3
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
  5. ASUS UX50V-RX05 Case Removal: 步骤 5 中的图像 1,2 ASUS UX50V-RX05 Case Removal: 步骤 5 中的图像 2,2
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
  6. ASUS UX50V-RX05 Case Removal: 步骤 6 中的图像 1,3 ASUS UX50V-RX05 Case Removal: 步骤 6 中的图像 2,3 ASUS UX50V-RX05 Case Removal: 步骤 6 中的图像 3,3
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
  7. ASUS UX50V-RX05 Case Removal: 步骤 7 中的图像 1,1
    • Carefully lift and remove the plastic cover to avoid damaging anything.
结论
James
于02/14/17注册
663 声望
创作了6篇指南
团队
USF Tampa, Team 20-2, Remmell Spring 2017 USF Tampa, Team 20-2, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G2
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 112
