跳转到主内容
ASUS U57A-BBL4 Front Panel Assembly Replacement
你所需要的
  1. ASUS U57A-BBL4 Front Panel Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 2 中的图像 1,1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 3 中的图像 1,1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: 步骤 4 中的图像 1,2 ASUS U57A-BBL4 Front Panel Assembly Replacement, Front Panel Assembly: 步骤 4 中的图像 2,2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 7 中的图像 1,2 ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 7 中的图像 2,2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 8 中的图像 1,2 ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 8 中的图像 2,2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 9 中的图像 1,3 ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 9 中的图像 2,3 ASUS U57A-BBL4 Front Panel Assembly Replacement: 步骤 9 中的图像 3,3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
结论
团队
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017 的会员
UMASSD-JULIE-F17S2G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 199
