跳转到主内容
ASUS U57A-BBL4 Display Assembly Replacement
你所需要的
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,2 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: 步骤 4 中的图像 1,3 ASUS U57A-BBL4 Display Assembly Replacement: 步骤 4 中的图像 2,3 ASUS U57A-BBL4 Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: 步骤 5 中的图像 1,2 ASUS U57A-BBL4 Display Assembly Replacement: 步骤 5 中的图像 2,2
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: 步骤 6 中的图像 1,2 ASUS U57A-BBL4 Display Assembly Replacement: 步骤 6 中的图像 2,2
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S2-G4, Julie Fall 2017 UMass Dartmouth, Team S2-G4, Julie Fall 2017 的会员
UMASSD-JULIE-F17S2G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 254
