简介
This guide will inform you on how to replace your hard drive. This replacement will be very easy as there are only a few screws that need to be taken out during this guide to access and remove the hard drive.
你所需要的
Turn the laptop over to the back.
Unscrew the two 3mm Phillips screws using a PH0 screwdriver.
Lift the small black panel upward by putting your fingernail in the provided slot.
即将完成!
结论
