跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
ASUS Transformer Book Flip TP500LA Fan Replacement
你所需要的
  1. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: 步骤 1 中的图像 1,3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: 步骤 1 中的图像 2,3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: 步骤 1 中的图像 3,3
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 2 中的图像 1,2 ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 2 中的图像 2,2
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: 步骤 3 中的图像 1,2 ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: 步骤 3 中的图像 2,2
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
  4. ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 4 中的图像 1,2 ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
  5. ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 5 中的图像 1,2 ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 5 中的图像 2,2
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
  6. ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 6 中的图像 1,2 ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 6 中的图像 2,2
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
  7. ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: 步骤 7 中的图像 1,2 ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: 步骤 7 中的图像 2,2
    • Unscrew the six 5 mm Phillips #0 screws.
  8. ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 8 中的图像 1,3 ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 8 中的图像 2,3 ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 8 中的图像 3,3
    • Grasp the top of the 3-pin connector with tweezers.
    • Wiggle the connector until it loosens itself from the motherboard.
    • Gently lift the connector from the motherboard attachment.
  9. ASUS Transformer Book Flip TP500LA Fan Replacement: 步骤 9 中的图像 1,1
    • Carefully lift the fan off the motherboard.
    • Attached to the fan is thermal pasting that needs to be reapplied when attaching the fan back to the motherboard. Follow this guide to reapply thermal pasting correctly.
结论
4等其他人完成本指南。
Solomon Dovinh
于04/10/17注册
403 声望
创作了2篇指南
团队
Cal Poly, Team S13-G5, Forte Spring 2017 Cal Poly, Team S13-G5, Forte Spring 2017 的会员
CPSU-FORTE-S17S13G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 1,915
