跳转到主内容
ASUS TUF Gaming FX505DY Wi-Fi Card Replacement
你所需要的
  1. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Solid State Drive: 步骤 5 中的图像 1,2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Solid State Drive: 步骤 5 中的图像 2,2
    • Remove the two 3 mm screws holding the solid state drive and its foil wrap in place using a Phillips #1 screwdriver.
    • The drive will pop up at an angle.
  6. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 6 中的图像 1,3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 6 中的图像 2,3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 6 中的图像 3,3
    • Slide the foil wrap off of the drive.
  7. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 7 中的图像 1,2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 7 中的图像 2,2
    • Remove the solid state drive by pulling it at an angle from the motherboard.
  8. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement, Wi-Fi Card: 步骤 8 中的图像 1,1
    • Remove the tape covering the Wi-Fi card.
  9. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 9 中的图像 1,3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 9 中的图像 2,3 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using ESD-safe tweezers, remove the two coaxial antennas by lifting up on the wires near the connectors.
  10. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 10 中的图像 1,2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 10 中的图像 2,2
    • Remove the 6 mm screw using a Phillips #1 screwdriver.
  11. ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 11 中的图像 1,2 ASUS TUF Gaming FX505DY Wi-Fi Card Replacement: 步骤 11 中的图像 2,2
    • Remove the Wi-Fi card by pulling it straight away from its slot.
结论
3等其他人完成本指南。
团队
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 75
过去 30 天: 351
总计 9,485
