跳转到主内容
ASUS TUF Gaming FX505DY Speakers Replacement
你所需要的
  1. ASUS TUF Gaming FX505DY Speakers Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 2 中的图像 1,2 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Speakers Replacement, Battery: 步骤 5 中的图像 1,3 ASUS TUF Gaming FX505DY Speakers Replacement, Battery: 步骤 5 中的图像 2,3 ASUS TUF Gaming FX505DY Speakers Replacement, Battery: 步骤 5 中的图像 3,3
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 6 中的图像 1,2 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 6 中的图像 2,2
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 7 中的图像 1,3 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 7 中的图像 2,3 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 7 中的图像 3,3
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 8 中的图像 1,1
    • Lift the battery up out of the computer.
  9. ASUS TUF Gaming FX505DY Speakers Replacement, Speakers: 步骤 9 中的图像 1,2 ASUS TUF Gaming FX505DY Speakers Replacement, Speakers: 步骤 9 中的图像 2,2
    • Lift the speakers from the pegs holding them down. Use minimal force as to not break the pegs or the speakers.
  10. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 10 中的图像 1,2 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 10 中的图像 2,2
    • Identify the place where the speaker cable connects to the motherboard. The port should be "SPK"
  11. ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 11 中的图像 1,2 ASUS TUF Gaming FX505DY Speakers Replacement: 步骤 11 中的图像 2,2
    • Pull the cable off the motherboard using a plastic pick or other pointed item and remove the speakers.
结论
Nick Pearcy
于03/28/23注册
313 声望
创作了3篇指南
团队
IUPUI, Team 2-3, Harley Spring 2023 IUPUI, Team 2-3, Harley Spring 2023 的会员
IUPUI-HARLEY-S23S2G3
3 名成员
创作了3篇指南
一条评论
model for the speaker. I want to buy a replacement , which one should I buy . I cant get original.
albert enstine - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 39
总计 499
