跳转到主内容
ASUS TUF Gaming FX505DY Solid State Drive Replacement
你所需要的
  1. ASUS TUF Gaming FX505DY Solid State Drive Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 2 中的图像 1,2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 1,2 ASUS TUF Gaming FX505DY Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 2,2
    • Remove the two 3 mm screws holding the solid state drive and its foil wrap in place using a Phillips #1 screwdriver.
    • The drive will pop up at an angle.
  6. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 6 中的图像 1,3 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 6 中的图像 2,3 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 6 中的图像 3,3
    • Slide the foil wrap off of the drive.
  7. ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 7 中的图像 1,2 ASUS TUF Gaming FX505DY Solid State Drive Replacement: 步骤 7 中的图像 2,2
    • Remove the solid state drive by pulling it at an angle from the motherboard.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 55
总计 1,041
