跳转到主内容
ASUS TUF Gaming FX505DY RAM Replacement
你所需要的
  1. ASUS TUF Gaming FX505DY RAM Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY RAM Replacement: 步骤 2 中的图像 1,2 ASUS TUF Gaming FX505DY RAM Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY RAM Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505DY RAM Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY RAM Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505DY RAM Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY RAM Replacement, RAM: 步骤 5 中的图像 1,2 ASUS TUF Gaming FX505DY RAM Replacement, RAM: 步骤 5 中的图像 2,2
    • Pull the motherboard clips away from the sides of the RAM chip.
    • The RAM chip will pop up at an angle.
  6. ASUS TUF Gaming FX505DY RAM Replacement: 步骤 6 中的图像 1,1
    • At an angle, gently but firmly pull the RAM chip to remove it from the slot.
    • To install RAM, insert the RAM into the slot and press flat until the clips make an audible "click."
结论
Carter Owen
于03/30/22注册
169 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 31
总计 934
