跳转到主内容
ASUS TUF Gaming FX505DY Charging Port Replacement
你所需要的
  1. ASUS TUF Gaming FX505DY Charging Port Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 2 中的图像 1,2 ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,3 ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,3 ASUS TUF Gaming FX505DY Charging Port Replacement, Charging Port: 步骤 5 中的图像 3,3
    • Using an ESD-safe spudger, disconnect the charging port connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 6 中的图像 1,2 ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 6 中的图像 2,2
    • Remove the two 6mm screws holding the screen hinge and charging port in place using a Phillips #1 screwdriver.
  7. ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 7 中的图像 1,3 ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 7 中的图像 2,3 ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 7 中的图像 3,3
    • Firmly lift the screen hinge out of the way.
    • The hinge supports the weight of the screen, so it is stiff. Use consistent force.
  8. ASUS TUF Gaming FX505DY Charging Port Replacement: 步骤 8 中的图像 1,1
    • Remove the charging port by lifting it free of the hole in the case.
    • It may require some shifting or angling to come free.
结论
团队
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 69
总计 1,827
