跳转到主内容
ASUS TUF Gaming FX505DY CMOS Battery Replacement
你所需要的
  1. ASUS TUF Gaming FX505DY CMOS Battery  Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: 步骤 2 中的图像 1,2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: 步骤 3 中的图像 1,2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: 步骤 4 中的图像 1,2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY CMOS Battery  Replacement, CMOS Battery: 步骤 5 中的图像 1,2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement, CMOS Battery: 步骤 5 中的图像 2,2
    • Gently insert the narrow end of a spudger beneath the CMOS battery and push in, raising the battery.
  6. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from its socket at an angle.
结论
Carter Owen
于03/30/22注册
169 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 119
总计 3,483
